jaggajatt
The Atrix is my first android phone so I'm learning as I go. I installed launcher pro on my phone just to see what the difference was. The problem I'm having is right after the Install, when I press the home button it directly switches to launcher pro and doesn't ask to "set it as default" and if I want to go back to blur i have to hold the home button down. I installed version 1.83 then tried 1.82 with the same thing. If anyone can tell me how to make it my default launcher it would be appreciated. Thanks.
P.s- Does disabling MotoBlur make that big of a difference on speed/battery life?
