Help Launcher Pro Doesn't load custom docks
Boba Fett
Well it does, but only after I tilt the screen to landscape and the dock moves to the right side of the screen. If I pick a dock that comes with LP, sometimes it works, but not always. I used to be able to just select the custom dock, press the home button and be taken to my home screen with the new dock on it. Not sure if the 2.3 update is making the phone finicky or what. Anyone else have this problem?
I've never had that issue and can change custom docks just fine. Try uninstalling/reinstalling LP? Or maybe clearing data from the manage applications menu?
