Root Launcher pro force close issues
stroltz35
I have recently found launcher pro app. I love the customization that it adds to my phone however I have run into an issue that I have search for but can not find a solution for. When I hold down a icon on my dock screen and choose change icon/ custom icon and find the one i want i will select it and it force closes every time. I am running the latest version of MIUI and launcher pro. Does anyone have an answer tot his problem. I posted it here on all things root because I was not sure if launcher pro was only for rooted phones. I apologize if this is in the wrong spot.
yeah miui and launcher pro have always had problems with eachother across all miui phones thats why i made the ics launcher pro what i did was set the icons and dock background in cm7 then put it on miui with titanium backup only thing is if you set custom icons for messaging and phone you need to have the same icons already set for miui's icons then change the schortcuts for those in miui
