I'm having problems with launcher pro. When i first started using it it was ok. Pretty smooth and a tiny bit laggy. But now it freezes and i have to do battery pulls a few times a day and its laggy as hell. My phone isn't rooted at all although i tried and failed and just left it at that. I've removed a lot of apps as well and that didn't help. When i remove launcher pro or switch to the stock launcher everything is fine and dandy.
Anybody have this problem before or anyone that can help troubleshoot this with me?
Thanks
Thanks
advanced settings in lp really alter performance...and if you have multiple launchers installed and widgets running on them you ll running memory so low you ll have fc's...i believe anytime you go under say 35mb ram free you ll start getting lp fc's
