Launcher Pro Icon Pack
So I've been messing with my new DroidX, and recently started using Launcher Pro. I found a sweet set of icons I like, in .apk format, and wanted to set them by going to preferences > theme settings > icon pack. I put the .apk on my side, but Launcher Pro doesn't know it's there. The menu just says none, and isn't seen by the program.
Is there a specific location I have to put the .apk file? If so, how do I get the file there? I have Astro (but don't really use it, yet). Also, should Launcher Pro be on my phone, or on my SD? Any clarification on all that would be much appreciated.
EDIT
After a bit of playing around, I realized I had to install the icon pack .apk first. Didn't realize that icon packs were "installed", just assumed that launcher pro would find the file and use the images contained within it.
