trophynuts
Extreme Android User
Has anyone used LP on CM7? if so did it work ok? Is it even possible? Do you just install it over top of ADW?
I'm running Liquid GB and LP is the default launcher. Works great, same as it always has, widgets and all. However, if you use it make sure to move any apps you might have off your sd card and onto your phone because it will cause LP to freeze and you'll have to force close every time you reboot. You might have to run a permission fix in Rom Manager, too. Had this problem myself and finally figured it out and have had zero issues since.
is liquid GB a CM7 based Rom?
I am and had no issues. Yes, just install it and you'll get prompted which launcher to use at the appropriate time.Has anyone used LP on CM7? if so did it work ok? Is it even possible? Do you just install it over top of ADW?
