Launcher Pro Plus
I just paid for and installed it! So far, so good.
One question, I installed Skyfire in order to install the file, but I cannot find a way to "exit" the browser. I have been using the home button to get back to the homescreen, but Skyfire opens on the last page I was on. Anyone have some experience with Skyfire and can help? I am used to Dolphin HD and it uses the menu button to show the exit button.
To remove the widget, press and hold on the title bar.
Thanks, but that wouldn't work either. I had to completely uninstall the app and reinstall it (thus losing all my settings).
For those still debating on whether or not to buy, I would wait. There are bugs right now with the people widget, and there is nothing else besides that.
I've been using the beta for a while now and bought the Plus version just to give the guy some love. Not even interested in using the people widget at the moment anyway so it's not an issue for me at all.
The way this guy updates and improves this app is terrific and I'm happy to drop him $2.99 as thanks for past efforts and in anticipation of updates to come.
bought it yesterday... happy to support a great developer.. 1 issue im having and wondering if anyone is having the same problem.. after rebooting all my icons change i have to go into pref and restore from backup... has this happened to anyone else and does anyone know of a way to fix this problem? thank you
I had to reboot several times yesterday messing around with camera 360 (ugh...). Anyways, all my icons were fine after restarting each time, so it seems like you have something weird going on.
My people widget doesn't use people Facebook pics... its just their names and blank. Any way to remedy this to just make it pull FB pics?
Ok, I bought this. The only issue I have with it is that I haven't been able to figure out how to change the apps that are linked to the dock bar. Any ideas on that?
For those with Facebook photos not appearing in the people widget, it is because Facebook restricts the access of third party apps. The dev has posted a workaround to this in the LauncherPro Plus forum at www.launcherpro.com.
I'd post a direct link or quote for you, but I'm at work and can't access his site from here.
I gotcha. You can use SyncMyPix
chart
and it will fill in the contacts pictures in the widget.
Been using the free version for a while now so have just upgraded to Pro. People widget all working ok, bring on the rest of them :)
For you guys having issues with FB pics not syncing, Have you gone through your Contacts and synced FB to those individuals.
I did day 1 when i got this phone, and the people widget works perfect for me, shows everyones FB pic.
Don't know if this is a stupid question, but I have it (Plus) on my phone while still running the Beta. Each time I hit "upgrade" under the install section of Astro it always fails. Someone earlier posted that you don't need to uninstall the Beta and I'd rather not have to reset up everything. Is there a fix?
