redlinezak
Member
If i install Launcher Pro can i choose which one to use (LP or Sense UI?). I have saved my current Sense theme so will i be able to just go back to that if i dont get on with LP.
Also is there anything i should do prior to installing (i have read that you should have a blank Sense before installing) but i see that there is a blank canvas option on the scenes.
Thanks
Nath
Thanks
Nath
