Terabethia
Android Expert
I have a quick question about the settings for Launcher Pro. I am sure the answer is no but I thought I'd ask anyway
Is there any way to set up custom preferences for each different screen? For instance, have your home screen only do 4 rows of icons while the other screens do 5 rows? Or have 1 screen turn off the app names while another screen still shows them?
And while I am in question mode, I just want to check on one other thing. I bought Folder Organizer and Better Cut. Can I use better cut to add custom icons to the folders I create?
I am pretty sure I can but reading another thread got me confused and made it seem like you can only do that with AppOrganizer, not Folder Organizer. Just want to make sure before I drive myself nuts trying to do something that is impossible.
