Launcher Pro Shortcuts
oaklane
I put at the bottom of my screen a shortcut for win amp and it will work the first time after I put the shortcut there but won't work after that. So I have to remove the shortcut and redo and it'll work. Anyone have this problem?
Thanks,
Thanks,
Not sure if this is the same issue I had, but once I moved my rouge app from SD card back to phone, I didn't have any problems.
Good luck!
