Does any one know where I can download the latest launcher pro themes. Blue in particular. Cuz for some reason it says mine is expired and cannot go to my homescreen.
Same problem, I am getting the same message as Launcher pro expired.
And for Saiyan_Prince i would suggest you uninstall the app or if you get a message error just press return and home screen button. The screen will be normal. Hope this helps you.
I did try pushing the home button and it just kept on saying its expired. I just went to launcher pro website by long pressing the home button n luckily the web browser was one of the apps to choose from. And I downloaded and intalled the latest version. N it looks like the blue theme is still there. N so far so good. I was freaking out at first cuz I couldn't uninstall or do anything. Now back to normal.
