HalfFrozen
I could have sworn I saw a LPP theme here where it was more sleek looking with white instead of black back grounds...
Any help would be greatly appreciated.
Do you have to be rooted to use these?
I dont believe rooting is required to change the launcher theme.
Yours IMHO is the best looking one man.
Im the one who actually created the Droid X themed LPP (The one with the white widgets). You can get my .apk from this thread: LauncherPro Forum • View topic - DroidX Theme
I also created a Galaxy S themed LPP found here: LauncherPro Forum • View topic - Galaxy S Theme
To run those things, do you have to have bought Launcher Pro Plus?
When he releases updates how does that work with this themed LPP.
So you have to have Launcher Pro Plus to get the widgets? In your installation instructions, you said that you need to uninstall Launcher Pro before installing the widget.
You uninstall the stock one, then install the themed one. When you go to put the widgets on your home screen, you have to re-enter the code you got when you bought LP Plus.
Gotcha!
It didn't when I installed it. All my homescreen settings and apps came back but none of the widgets loaded. When I tried to put back the People widget (the only LPP widget I use) it told me to upgrade to the paid version.
You have to re-enter your unlock code
IF YOU HAVE INSTALLED ONE OF MY LP MOD'S IN THE PAST, YOU CAN INSTALL ANY ONE OF THESE APK'S OVER THE EXISTING LP.
IF NOT, YOU MUST UNINSTALL PREVIOUS VERSIONS OF LAUNCHERPRO PRIOR TO INSTALLING (either through ADB, file manager or the Market). Make sure you backup your LP settings, then install as normal via Estrongs, Astro, etc. You will still need to enter your Paypal info for the paid version.
