Launcher Pro update..... lost my lock screen?
stevep94
I've done an update for Launcher Pro today and now I can't seem to get the lock screen back as it has gone back to the standard Sense lock that you drag down!
Can anyone point me in the direction of how to fix this?
Thanks muchly,
SteveP
Were you using widgetlocker or something like that? Those apps typically work by being a home replacement that then directs to whatever launcher you actually want to use. You must have selected Launcherpro as your default after the update. You can probably use home switcher or something like that to change it back.
Just updated WidgetLocker and my lock screen wallpaper was gone - just a plain black background. Restarted the phone and still black :( I have all my lockscreen widgets and custom sliders still there, just no wallpaper!
EDIT: found the problem, 'background tint' was set to 100% after the update, reducing it to 0% revealed the wallpaper again :)
Thanks for all the replies guys - like an idiot I thought the lock screen was part of LP rather than Widget Locker!
Thanks for the kick-start to my brain!
SteveP
