SinfulDragon
Anyone having issues with Launcher Pro update installing?
I'm running UD 1.0.0, other updates install, just not LP.
There IS a way to do it, but it's a roundabout way. You need to save your homescreen settings, install the ADW Launcher (so you have SOME kind of home launcher), then use root explorer to go into system/apps and delete the launcherpro.apk. Then reboot the phone and download LauncherPro's updated version from the market. Restore settings and widgets and you're in business. I'm not sure the update is worth the trouble, IMHO.
With the YouTube update you can uninstall YouTube in Titanium Backup, reboot and reinstall from the market.
I'm hoping that BD will fix this issue in his update.
that sounds pretty annoying. why do you have to do that with some roms?
I get the reasons, but thats wildly annoying and I'm not installing another launcher just so I have the ability to update LP as the FB Widget is not used on my phone anyway.
Thanks everyone for the responses.
