Launcher Pro
Dudditz
Ok guys, probably being really stupid here but I have just installed launcher pro and I have set it up with 5 screens.
I want the middle screen to be my default home screen, much like it is in sense but no matter what I do I cannot seem to get it to default to this no matter what number I pick.
What number should I pick or what am I doing wrong.
HELP!!
I have downloaded and un installed it 4 times in the past 24 hours but even though it says its downloaded I am buggered if I can find it. I am missing something incredibly obvious aren't I
Its not really a case of finding it. You press the 'Home' key and select it. If that doesn't work, go into applications>manage applications>htc sense>clear defaults. Then press the 'Home' key and select launcher pro.
launcher pro is good overall, no slow downs till now. smooth sailing. the option to move between screens using the trackpad doesnt seem to be thr in laucher pro, as thr is in the HTC sense. the transition effect is launcher pro is coool though. is thr option to import my sense widgets over to the launcher pro screens???
I find the 3d app drawer is making the change between screens very jerky and unstable. I like it though (3d app drawer) just not willing to run it at the moment if it is unstable.
eh? The 3d app drawer doesn't change between screens. Are you sure are using the latest version? It's super smooth for me.
Yeah I didn't explain that well at all, with the 3d app drawer enable I find the whole thing laggy, especially change between screen.
With it disabled, it is a whole lot more smooth.
Guys, I just found Launcher pro and have to say it's absolutely brilliant! I am having such a good experience running it. I have the HTC sense and the only thing that I really miss (now that I'm not using HTC sense any more) is the main clock/weather widget. What's the closest equivalent to that (look and functionality)?
---Can't wait for Froyo... as there are so many great apps now I keep running out of space!!!!!
