Might anyone know anything about LauncherPro??
I want to use it...truly do. But it seems so hard to use. I have figured out how to enlarge it to 7 screens. But there is an icon, second from the left on the bottom. I am certain it is contacts BUT IT SAYS 'UNABLE TO FUNCTION' Or something of that sort??
And I simply don't know how to use it. Can u give me ANY basic pointers.
I did figure out how to switch between the Vibrants own starter program and that using Home Switcher.
Thanks a lot
Eric
ps
As an aside I was unable to use my yahoo email with the Vibrant EMail. someone said that secondary programs are usually not as good at handling Yahoo email, to either stick with the Yahoo email program Tmo support recommended (which is why I am asking--i dislike it..have that terrible opening screen which makes it so slow) OR to go with some other program (i forget)
Any comments on that, if u understand??
Again, thanks a ton
Thanks a lot
Eric
ps
Again, thanks a ton
