Help Launcher Pro
marco712
Member
I've recently bought a Milestone (moved from HTC hero), and something that I have noticed and been a little frustrated with is how Launcher Pro behaves.
I noticed that if I use a program for a certain length of time (eg. I surf the net, or play a game. ) When I return to the homescreen, NONE of my widgets are there. I need to wait a few moments for them to reload, or swipe through the screen until the widgets pop up again.
I've tried to uninstall/reinstall as well as clear the cache/data settings in Launcher Pro, but the problem/lag still remains.
Has anyone else experienced this?
There are quite a few settings for memory in LP and I think that is where you should start.
Yes I have the full version and it works awesome! I have a task manager as well but any other one but "Task Manager" seems to screw my phone up. They have the same icon and I was fooled the first time I re-installed my apps after a wipe of the OS.
Don't get confused there is a lot that look alike!
Direct Link
hmmm ok, so i've uninstalled my "task killer". and I've moved launcher pro to "internal memory"
I still get the widgets loading , albeit less often. I'm wondering what settings I should use for the memory settings?
Straight from the LauncherPro website:
"Improved some code which should make screen rotations a little bit faster. Please note that android KILLS the homescreens when rotating, so all widgets, icons, etc. have to be redrawn. That’s just how Android works."
