Root launcher pro
3VOcrack
does anyone know exactly how to install the docs and icons once I pick the ones I want from Launcher Pro? I downloaded the dock I want and its sitting in my gallery to view. I dont know how to install it as my dock to use.
not sure in Launcher Pro I use Go Launcher. I just hit my menu key and choose themes not sure if Launcher give you the same options or not.
Hit Menu -> Preferences -> Appearance settings -> Dock background -> Custom -> and pick from your gallery
..atleast this is the way with launcherpro plus
Exactly.
Also if you want to change the icons of all of the home screen apps, when you long press on the home screen and select app you see a small picture off the app icon. click on the icon and you can choose from your gallery what icon you want to display.
I think the options you have with LP are the easiest way to "theme" your homescreen. You don't have to mess with framewrk files and such. ;)
