Launcher replacements hide Samsung widgets
linuxdood
Not that they are any good but when you install a home replacement like launcher pro or zeam the Samsung widgets are no longer an option. Anyone find a way to load them? Anyone care?
Part of a "launcher" implementation is the ability to add widgets, and it appears they're rolled into the launcher code (vs. being separate packages). I actually kind of dig on the feed TW widget, and wouldn't mind having that in another launcher.
As I understand it you'd need to back it out and re-implement it as a separate widget or into the codebase of another launcher, which isn't exactly trivial.
