Started using launcherpro earlier this week and absolutely love it. My battery life has gone up tremendously.
I have one issue that I haven't seen any reports on. When using launcherpro and I go into the dialer it doesn't recognize some of the first characters that you type.. Mainly it doesn't recognize the * key, but it will show it on the screen. To give you an example (if your devices do it too) go in and type *#*#4636#*#*.. It will not recognize that first star. It also doesn't work with the voicemail shortcut when you click and hold the 1.
Here's the kicker, when I say it doesn't work that is partially true. You can make it work which is the weird part, If you type something then clear it and redo the key sequences everything works as normal.
Hope this makes sense as this is a weird bug and hard to describe.. I don't know if the issue is with HTC's dialer or with Launcherpro. I did try other home screen replacements and didn't have this issue.
