Root LauncherPro and HTC Sense
DavidG6
Hey everyone!
I love my little rooted Eris (running xtrSENSE)! I posted before about this kind of, but I get bored after a bit with the look of it. I have switched to Launcher Pro Plus and have the basic look it provides, so with that being said I have two questions!
1. How could I switch back to HTC Sense (without losing or deleting LauncherPro)?
2. How can I find other "looks" if you will to download onto my Eris to spice up my LauncherPro look?
Thanks!
Hey everyone!
Yes. There are two things that you can do:
From home, settings->applications->manage applications. Wait for it to refresh, find Launcher Pro and tap it, scroll down to find the button that says "clear defaults" and tap it, then press Home. It will ask which launcher you want to go home to, with a check mark to make that one the default.
(Easier) Install the app Home Switcher from the market and use that to set the default launcher. https://market.android.com/details?id=ymst.android.homeswitcher&feature=search_result (make sure that you install this one and not the one for Froyo.)
Thanks!
This is one of my favorite things about launcherpro. Check out this thread for custom dock backgrounds: LauncherPro Forum • View topic - Share your custom dock backgrounds! Some of them are no longer visible if they were attachments. Check some of the later pages.
You can also search that forum and xda's forum for icons you can use on the dock.
If you want some examples, I can upload screen shots from different looks I've set up when I get home from work tonight.
Thanks! This is great! I will check out everything. Just trying to bring some more life into my little Eris. Going on a year and half with this guy.
