gocardinals
I've just started experimenting with LauncherPro. Question: How do I get a full month-view calendar to show up, instead of just one event?Thanks.
Oh ok. I know what your doing. You have to go to LauncherPro widgets.. your using the calendar widget for just android... Sun 8 is Sunday the 8th....
ANOTHER NOTE.. LauncherPro widgets will also only work if your buy the Plus version.
LauncherPro toward the bottom, you have to go thru paypal and you get a unlock code. He does this cause he does not live in a country that can post buyable apps on the official android market.Thanks everyone. How much is the Plus version? Is it worth it, and what do you get? I appreciate the help.
