Help launcherpro half vanishing dock ??
skoodbeef
I have an issue with the dock icons on launcherpro.
If I use the hide status bar option I get an empty
Black bar at the top and half the icons are pushed down at
The bottom of the screen. Not all the time just now and again.
The icons stil function ......but its very annoying!
I know its probably linked to an app I'm running
But I can't find which one after many deletes and
Reinstalls. Any similar problems or solutions anyone??
Happens to me.
Sometimes home, app drawer or unhide/hide status bar clears it. Failing that, screen off, on and unlock.
Only solution I've found
Sorted. Basically moved the fuzzy clock widget
Further down on homescreen.
Not exactly ideal but it will have to do til Launcherpro
Sort the bug.
