Help LauncherPro Making Incredible Slow?
RxCate
I installed LauncherPro after reading a few of the threads on here about it, and have noticed that now, my phone lags... a lot.
Before I uninstall it out of frustration, are there any other possible solutions?
I turn orientation off, and have some sort of caching on in the options (menu preferences) for it. That alleviated any slowness I experienced from it.
The only slowness I get is when I try to add/change something on the dock. Takes forever for the list of programs or widgets to show up.
It was crazy slow! I used it for like a week and was satisfied with the stock Android experience, then went back to Sense and I couldn't believe how much faster it was. I know someone with a Moto Droid 2.2, and even with 2.2 the Incredible is much faster browsing through menus & home screens. Sense just seems to be smoother than stock Android. I'm not even that big of a fan of Sense either.
I even set a task killer to auto-kill sense so I wasn't running 2 launchers....still didn't work
Wow... this is surprising. The reason I use LauncherPro is because it's the only launcher I've found that's FASTER than stock, with the number of widgets I run.
You should play around with the memory settings if the performance is slow.
Launcher pro was faster than stock android on my moto droid but it actually slowed down my Incredible...Sense was faster...im pissed cuz i bought Launcher pro plus...
I just downloaded and started using LP a few days ago. I like the looks of it and think the dev has done an amazing job.... but it's slow on my phone, too. And it FC's a ton.
I'll mess with the memory settings to see if that helps.
I bought the Pro version when it came out also. Recently I've noticed it being a little slower, but I won't be removing it. The dev is adding more widgets, functionality and releasing updates pretty often. Actually, I expect to see some issues with an app that is in active development.
Basically if you don't like how it's working wait a few days I
I literally spent 8 hours customizing Beautiful Widgets, WidgetLocker, and LauncherPro to perfection yesterday, only to uninstall them at the end of a long night because my phone lagged so much. With WidgetLocker, I couldn't use the stock HTC slider because it would lag like crazy upon unlock and flash between the lock screen and home screen. LauncherPro stuttered so much trying to switch between home screens, it was like I was trying to fight against the elasticity. It also lagged in menus and settings and was just generally an unpleasant experience. I liked Beautiful Widgets, but there was no reason to keep it installed without LP, seeing as I like the stock weather/clock the best.
TL;DR: Absolutely loved the way my phone looked, but not about to trade functionality for appearance. Dinc was just too slow.
OK, this is weird.
I was running the leaked OTA and leaked Froyo ROM and installed Launcher Pro. Ran GREAT. No slowdowns whatsoever.
However, last night I decided to return to stock in preparation for the official OTA update(s).
Installed Launcher Pro and am noticing the same slowdowns others are talking about here.
Not sure why, but on stock 2.1, Launcher Pro is A LOT slower than on the leaked OTA/Froyo I was previously running.
Guess I'll stick with stock SenseUI for now...
Im running LP Plus, Beautiful Widgets and WidgetLocker on stock 2.1 and everything is like butter. The ONLY issue I can report is if I hit the power button then IMMEDIATLY turn the phone back on I can see my LP home screen for a very brief moment before WidgetLocker takes over.
Open your LP settings and change the memory profile to "High" also make sure your using compressed cache for your homescreen caches. After reading the LP forums, that seems to be the magical settings for the best smoothness on newer devices.
