Launcherpro Screwy
ltb3
Don't know what happened, running aosp gingerbread, launcherpro just flat took a dump. Cannot open anything, screen is blank below the top bar. Tested it, could receive a text message, but didn't have a spare phone handy to try and call. Can't get any menus up, holding the home button pops up a force close box, had to revert to a back up. Any way I can get the problem fixed? I don't really want to have to set everything up again.
Thanks!
Thanks!
Did you try just a reboot? And also try a reboot to recovery and wipe cache and davlik cache then reboot and see if that helps? If none of those work you could try another launcher delete launcher pro and then reinstall launcher pro and see if it runs better.
I rebooted, cussed it, rebooted, cussed it, rebooted........ You get the idea. lol
Haven't tried to wipe anything, I'll give that a shot.
Can't delete the launcher, because I can't get anything to come up. Guess I could try to hook it up and do it manually, but was hoping it was just an easy fix.
Thanks for the ideas
Yea definitely try to wipe cache and davlik cache and see if that helps. Also what version of asop gb are you on? Theres a new one out from 4/29 that you could flash over your present version after just wiping cache and davlik cache so you don't have to resetup. Or you could just reflash your current version over what you have now after wiping both caches and see if that clears it up.
Sounds like you may have lost the default for your browser, I would simply reflash the Rom, that will allow you to have the current launcher that come with it, and then you can use that, and uninstall LP, then download it again, and then you can simply set it up again and see if that resolves your issue, this happens something when switching to an older Nandroid Backup, and LP had an update and no longer works and needs the new version to work.
