Help Launcherpro Setting
keerf
Member
Hi All,
I have a question for everyone who uses Launcherpro.
I was using the plus version of LP, but it seemed to run pretty slow on my phone. Usually with menu selections (aka widget selection, or app selection when long pressing on the screen). The widgets also didn't update properly etc.
I'm curious though is it might of been some advanced settings that I didn't play with. I typically just did an install setup my dock and homescreen, but never touched the advanced settings.
Does anyone have some advanced settings they could share? Also my phone isn't rooted, would that cause all the lag with it? Cause honestly TW runs fine.
Thanks all
Hi All,
Thanks all
play with the speed settings under advanced...it ll really make things run faster.
