Help LauncherPro Update Issue
Rossco_Pee
All,
I just updated LP and am now getting a FC each time I try to scroll through the apps in the app launcher. Is anyone else having this issue. I've tried rebooting and reinstalling with no luck.
Edit: I am running XTRrom 5.0.
All,
I'm running GSB 2.3 and installed the update earlier. I haven't had any problems like the one you are describing. I did move the launcher pro apk to the system/app folder and installed it there. I would try that to see if it is more stable.
All,
I have the same problem and posted it in the LauncherPro forum ... there are a few others having the same problem. Hopefuly Fede will respond and fix the issue
Edit: Fede is now aware of the problem and said it will be fixed shortly
