Help launching launcher pro
pwrshft99
Member
After updating to reptile, I downloaded Launcher pro but when I was prompted I set sense to default. Now I cannot get back to launcher pro, I uninstalled and re installed it but no luck.
download Home switcher (free - market)
Works well if you want to go back and forth while you test out Launcher
The API has changed and Home Switcher is no longer capable of setting a default. I hope that the app can be updated to work as it used to. But, I don't have a good feeling about it. To clear HTS Sense as launcher you either have to go through the following Menu >> Setting >> Applications >> Manage applications >> HTC Sense >> Clear Defaults >> Home Button >> select a new default launcher. Or you can use ClearDefaultHome >> Clear Defaults >> Home Button >> select a new default launcher. ClearDefaultHome just saves a few steps for us lazy folk.
