Help layout of keyboard
SirSpace
This might be a stupid question but before I rooted I had the latest updates for my phone software and all that BS. When I rooted I noticed the keyboard went back to the layout before the update. Is there any program that will allow me to change layout of keyboard like how it was when my phone wasent rooted?
You could get a theme for the keyboard, i know sometimes it can slightly change the keys, or even just get an app like SwiftKey that will change your keyboard entirely, then you can theme it.
Just suggestions :)
Thanks digi that's exactly what I want to do change the keys around cause I liked the layout before I rooted
Digi I downloaded swift key and it fixed it tysm for that but you know where I can get full version pirate by has it but no seeders all leechers
This forum does not support piracy. And any discussion of it will result in infractions ;)
Developers put quite a bit of hard work into these apps, if there is a paid version, its because they think that work is worth some compensation.
The least you could do is actually SUPPORT the app you seem to be fond of :rolleyes:;)
Sorry for lord I didn't know :( but when you don't have a cc to buy it that's kinda hard to do again sorry about post
This is correct the site doesn't look too fondly against piraters.
However, don't be upset you are not being warned yet ;)
Anyhow, it is only a couple dollars the least you could do is support the creators of it, they put in a lot of hard work to keep that app up and running.
Also the original keyboard should be the removed apps.zip that bloodawn posted in the first post of the ctmod thread. There are also instructions on how to install it.
And he's right... I'm not staff, and I can't hand out infraction, I was just offering a friendly warning before you got into any unwanted trouble. They are fairly strict around here about that.
And on a side note, you don't need a credit card... you an use a bank card or even get a prepaid debit card... there are plenty of options besides stealing
