Laza zcell 5400mah battery
Well so far so good. I've only done one charge cycle so I have four more to go for full capacity. Ten hours and thirty eight minutes with sixty seven percent battery left. Worth the $22 for me. The back plate is a smooth rubber. Its thin at the top then pops out a little less than half way. Where it sticks out its rounded off on the edges except at the top. Which is OK because it gives you a nice place to rest your index finger. So nice not to have to worry about battery life
just wondering what were your settings for those results ( i.e. 10 hours 38 minutes with 67% remaining) Particularly wondering what your brightness setting was at. Also did you have power saving mode turned on? Thanks!
I'm rooted using the stock ics rom. I've also disabled a bunch of stuff. I use juice defender, and my screen brightness is 0. I got over 24 hours last charge. I wish I would have took a screen shot but didn't think about it. I'm very happy with this battery. For the price you can't beat it. Ill probably start upping the brightness etc after my first five charges. Although I'm so use to it I might not.
I haven't been using my phone as much but still. Pretty awesome
Got the battery today. Popped it in and it was at 80%...guess I gotta do the 5 cycle full charge/discharge thing. Does that mean letting it completely die to shutdown then fully charge...or get down to about 3-4% then fully charging?
What happens if its bed time and tis down to 15% or so and I charge it for the night?
The only complaint I have so far is the hump is a lot bigger than I thought it would be. I can't fit it in my GPS holder in my car anymore.
my phone actually sat on 37% for a while...now it says 38% lol.
Is Juice Defender even worth using along with this?
I'm getting this! But I'd rather the Mugen back w/the stand. $40 or so combined is a lot better than near $100! Anyone know if the 2 are compatible?
months later, this battery and my stock battery seem to be draining so quickly and I have no idea why. I'm running Jellybeer rom right now. Woke up to 100% at about 9AM..by 10:30AM with some texting and maybe 10 minutes of GPS i was down to 65%
