Root LCD Desnity/ETC , Help!
O
old_member
Guest
Ok , You may have seen me from the forums , I need your help! I really want to change my LCD Density , But then the google play store goes wonk , It says allmost everything is incompatible , How can I change my density , And keep my Google Play store how it is!:(
I would also like to somehow underclock my device , What app do you recommend , How much battery do you save , And would you recommend underclocking?:confused::confused:
I would also like the Stock "SystemUI.apk" Please , If you have it , I thank you! A million salutes (One ... Two .... Three... Four... This is alot):)
Also I would like to get the full Xperia UI , Please do tell :) :)
If you can help in all of these , I might actually even consider putting my credit card and donating a few $20's to you .... I might since I never use PayPal or anything like that , And my Bank is strict with what I sign up for!:o
1)if you do that than you need to change your devices footprint
2)i use titanium to underclock
the others i know not what you speak of
Hey , How do I change my device footprint?
Tell me please! Can you give me steps?
I use the app "lcd density modder".
no frills cpu is the best tuner i've used really imo. haven't messed with cpu of this phone tho, never rooted it.
+its free, or atleast there's a free version.
Rom Toolbox has almost every tool you'd need to mess around with your phone...a cpu scaler...build.prop editor
as for the stock xperia ui you might wanna check xda for that...and the xperia forum, i'm not sure if anyone here has an xperia...
I under clock to 810 mhz on demand govener for most of the time. I figure it's still a dual core even clocked at 50% speed (I'm used to a 1ghz single core) ... it's still fast enough to do everything, play games, browse the Web, not lighting fast but still quick and relatively lag free... In an hour of idle time It MIGHT use 1% and I'm coming from a galaxy attain so this is great! I almost never clock it to 1.5 unless I'm trying to show off to my sister that just got a new iPhone 5 :)
