tried to install via OEM recovery, and with bootstrap recovery and both failed.![]()
Did you change the file name to "update.zip?"
Sure did. made sure to do that asap. do you think it is because I removed the "bloat-ware" do I have to reinstall it all or SBF first? I am not using a custom rom at all.
from what I read on XDA you have to SBF over stock 2.3.4. I'm pretty sure you can't be rooted either if it's a leaked "OTA".
ok, so I got it installed, but now my screens scroll real choppy?![]()
Just curious as to why..negative, I went back to my X2, sold my Bionic.
probably because it's a Motorola, the buggiest phones ever made...???![]()
