Help LED doesn't works when display is on
thahim
I had GS3 before on which LED didn't worked when the display was on, I have GS4 now but i can't figure out if the LED will blink when display is on or not?
In my experience, it should even work. Why would it blink the led if it knows you are looking at the screen and will see the notification anyway?
I agree...this is a feature I would like to see an option for so you can have the LED stay on even with the screen on.
The LED does work when the screen is on, if you have ever used watchON then you will notice that the LED comes on when using the remote control features.
Lightflow app on play store should be able to do that for you - but be aware that on the s4 (due to how Samsung has coded the accessibility features), it may cause the phone to speak some of your selections out to you - example: it may say "checkbox selected" when you select pictures from your gallery. From what I've read, it is a Samsung bug (doesn't occur on any of my other devices)
