LED indicator light
elhamda
Member
LG Motion is generally a decent phone. However, one really good feature missing from this phone is a LED indicator option. Has anyone found a good solution or alternative for it?
it can be bad on your battery if you a. have the screen at full brightness and b. leave it on silent and say get a text message while you're asleep. Really depends on how often you check your phone.
As for the permissions I haven't noticed any issues or anything.
I installed it and so far it seems to be doing exactly what I was looking for. I have set it to disable for hours between 11pm and 7am, so that should help with the battery drain issue in case of a late night text/email.
Or just get Permissions Free app from the market and disable whatever permissions you don't like and see if the app still works.
Have not tried the Permissions Free app on this phone, it worked great on my Esteem.
