Help LED light changer app..
yup sadly it is just a bi-color led. Funny thing though mine normally would flash green on texts and stuff, but now all of the sudden for some reason, throughout the history of the million flashes and mods I have tried working on my ROM, it now flashes amber instead of green all the time lol!!
But yeah a led color changing app probably won't work on this phone!
No, never have. I downloaded an LED changer to test and the only color that would come on was red. Do you think that's a ROM thing?
No, it's possible but it's been like that on every ROM I've used, anyway.
So what happens when your phone reaches 100%?
Maybe that app screwed it up?
mine was green for notifications on stock rom, red while charging, green while done charging.
now i dont see green anymore unless its done charging. i would like green for notifications, i always am wigging out thinking my phone is on its last 10 percent (pulsing red light) but its just a notification.
No, I just installed the app the other day. When it gets to 100% the LED just turns off and I've never received a green LED since I've had the mt.
The green part of the LED probably got damaged somehow so it doesn't light up when it's supposed to then. You might want to think about getting a replacement.
I checked again and it seems it's lighting up red everywhere it should be green, despite being set to be green. You're probably right about the damage though. Should I contact Motorola or VM about it? And do you think it's worth it if everything else works perfectly, because it doesn't have any of the problems I've seen others mentioning. Sorry for the slight derailment, I just thought it would be better here than in a new topic.
I would contact VM. If it doesn't bother you, then there really isn't a need to I guess, but there is always that option.
