Root LED light...
if you take a flashlight it looks as if there are 3 small holes possibly LED's of some sort directly left of the Sprint logo at top of the device. anyone know the reasoning of this spot?
It's called FlashNotify and it works pretty good. It links you're whole screen on and off at user specific intervals. I had mine being for missed calls and sms every 5 seconds and turn Tue screen off every 1 seconds and for the app to stop blinking after 15 minutes.
Sent from my DamagedControl using Tapatalk
yeah i tried that for a little bit, but found it got really annoyiing really quick
