LED Not Working
Jebus
Member
I use the Handcent SMS and the LED color (blue) and it worked perfectly fine. I set the color to a custom color now and when I get a text, the LED for SMS doesn't show up. I also have the custom color off now too.
I also have Missed Call. I used it to set a color for the SMS LED, but it still does not work.
Does anyone know how to fix this issue?
I use both Missed Call and Handcent SMS and there is no reason to have Missed Call interact with SMS/MMS handling as Handcent manages it all.
I would delete the profile in Missed Call for your SMS, and reset it in Handcent and use Handcent only to manage that LED.
Does the LED work for other things? Also, have you used the "test" function in Handcent to test our Notification settings?
glad it work, they likely just conflicted each other. I only used Missed Call to set LEDs for those that do not natively... like a missed call ironically - which I use purple for
