LED Notification Light Duration?
Barats
Sorry if there is already a thread on this. But for the LED notification light for when emails, texts, etc come through, how can you change the duration of how long it blinks? Like on my Evo, if I received a text, the light would only blink for about 5 minutes before it stopped. Or until I received another notification.
Thanks.
I don't know if there is a specific way on stock settings to change it, but i know with the app Lite Flow, even with the free one, you can change the duration of the notification as well as the color and vibrations it makes.
Cool thanks man! Yeah for the Evo, the default setting was about 5 minutes or so. Seems the Note 2 blinks until you check it. Only setting I found was under Display and it was either turn the light on or off. I will check out that app, though.
