Help LED Notification light?
I have never gotten anything other then RED, BLUE, GREEN, MAGENTA to turn on for anything that makes them turn on
however I have seen RED, BLUE, MAGENTA, YELLOW, CYAN, GREEN and I think WHITE
I have seen these colors when doing various things like flashing roms and causing system errors from modding things but have never gotten them to turn on with any of the LED apps
also recently there was an update to the app gmail notifier and now MAGENTA doesnet work - before I had to set the color to YELLOW and it would make MAGENTA turn on but now that doesent happen anymore
You could try Missed Call, but I think that if you are on Froyo, it doesn't work.
There are several others which I cannot remember the names off the top of my head...
Usually that can be done within the notification settings of the individual applications.
Unless that program is something like K9 Mail (which allows you to set the LED notifications to any across the spectrum - which the phone won't recognize) or many of the stock apps don't allow it.
which goes without saying....
I have messed with all the led color programs out there and still this is all I get
What apps/programs are you using to get those colors? I've tried to mess around with all different colors, and the only ones I can get are blue and red.
I'm using "Missed Reminder" (from the Market) to get those colors too. Would like to be able to get Green, White, Magenta, whatever, if possible.
Ideally, I'd like to set different colors for different contacts, but I don't think that's doable.
