Help LED Notification When charging - any way to modify?
oldweasel
Trying to see if there are any apps (root or otherwise) that would discable the constant LED while charging so that I could see the flashing LED notifications (for emails, SMSs, etc) while the phone is charging?
Or are there any apps that might flash the screen, etc when a notification triggerable item comes in when the phone is charging and the screen turned off?
Just trying to stop missing SMS and emails at work just because my phone is charging.
Thanks in advance!
Try NoLED from the market. I remember looking at that when I was thinking of getting the Nexus S and there was no LED indicator. It flashes something on the screen. May or may not work.
You can click on the link and it will take you to it in the market.
Thanks, looks like a powerfrul app, I'll give it a try!
