Help LED Text App
stauren1203
Are there any text apps which use the LED to notify of text messages? I used Handcent on my DX and since I walk away from my phone a lot I like having the LED blinking, but I'm not getting it on the TBolt. Is anyone using a different Text app which uses the LED for notification?
from the home screen: menu> settings> display> notification flash
if it's still not working, factory reset.
I appreciate you posting this. I was going to post the same thing earlier and then I realized that the setting my be specific to the GB ROM I am running. Good to see that menu option is available in the stock ROM too.
GMB
