Root LeeDroid 5.0
El Presidente
Beware The Milky Pirate!
I know this was popular "back in the day", but he didn't update for ages and one of the best Sense ROMs faded into nothing.
It looks as though he's updated again, based off the 3.12.405.1 update and has given things a bit of an overhaul. There are tons of new features, including his own LeeDroid Tweaks app.
The Changelog is here:
LeeDrOiD_HD_V5.0.0 6th February 2012
Re-Based on HTC WWE 3.12.405.1 RUU - Sense 3.0
Removed all HTC Loggers
Huge system cleanups
Kernel V4.0.0 included
Updated all preinstalled apps
New Bootanimation
Lots of system tweaks & fixups
Fancy keyboard animations
3D Home screen toggle
Added advanced power menus
Added CRT on/off animation
Added bravia engine
All previos LeeDrOiD mods included
Ported LeeDrOiD Tweaks from my Evo 3D builds(Thanks to the awsome j4n87 & daniels7)
select power/vol-/vol- button to wake device
choose between Sense, ASOP and Honeycomb lockscreen
custom carrier lockscreen text
toggle to use volume buttons to skip tracks forward and backwards
toggle items on Lockscreen: Carrier/Time/Date
toggle to use menu key for ALL Lockscreen
define another app to the right softkey of the sense bar
toggle between normal/supersmooth and ultra smooth rosie (Thanks to hamdir for his original)
unlock animation toggle(annoying carousell animation, each time you unlock)
5 column app drawer toggle
paginated app drawer toggle
disable sense launcher running in background: saves memory when using another launcher
Phone Info: menu when you type *#*#4636#*#* in the dialer
Dim the backlight of capacitive buttons
choose between normal/low and lowest autobrightness values: battery saver!
choose betwen TEN different overscroll colors
toggle to turn screen on, when sms arrives
toggle crt animations
just available on Leedroid Tweaks: "Screen Always on" Quicksetting
AutoSync Quicksetting
Leedroid Tweaks Quicksetting: Links you to the Tweaks
Honestly guys.... there is too much to list!
[ROM]LeeDrOiD HD V5.0.0 - 5th Feb | Tweaks | APM | Fast | Stable | Pure Awsomeness! - xda-developers. Looks to be well worth a punt if you fancy a Sense based ROM.
Can someone running this ROM download 'Evi' from the market and see if the speech search works?? That would tempt me away from Absolution!!
I'm gonna give it a go in a minute, as El P will tell you I'm LeeDrOiD and loyal. Well chuffed he decided to give us another shot and apparently with further updates over the latter end of the week and the 9 days after he is going to be working on it.
You got a cut from every donation he received didn't you? :p
What was the deal? Did he just move on to another device? I'm sure I heard he'd moved house or something and just didn't have time.
