Root LeeDroid question
bigt
Hello
I have a rooted One S running LeeDroid v2.10 and when I turn on quick settings I lose access to my ongoing notifications when I pull down the status bar. Has anyone else got this issue?
Okay, I just flashed it and the quick settings only show up for me when I have no other notifications. Otherwise it shows the notifications.
You did a full wipe/clean install? Have you rebooted after messing with the quick settings?
I really don't have much troubleshooting help for you here besides basic stuff. If you have done all of that, it may be best to reflash it and see if that helps at all.
Normal notifications (eg new email, new message etc) act fine (ie over rule the quick settings), but it is just ongoing ones (eg song playing in Google music) don't. The little icon appears on the status bar but when I pull it down I just see quick settings (unless there is a normal notifications too which hides the quick settings and allows the ongoing notification to be shown).
I have rebooted lots, and rewiped and reflashed.
It is not really a major problem and I think LeeDroid is/are releasing a new version soon
I flashed a different ROM before I saw that. It sounds like something you could bring to the dev's attention.
Like you said, it's fairly minor, but I use it enough that I would find it annoying. ;)
A bit of an update.... I spa^H^H^H posted more in the general section of XDA so I could post in the development bit (silly rule if you ask me) and it turns out a few LeeDroid users have the same problem.
Yeah, I understand why they have that rule, but I don't really like it myself.
So it's probably a ROM issue, and not you specifically.
I dont use Leedroid but have tried it and I'm pretty sure that it's a setting in Leedroid tweaks. I'm not sure exactly which one but the One S doesn't have many so shouldn't be too difficult to find. If I end up restoring my Nandroid before you find it I'll let you know what it is.
It's in the system ui tab of tweaks. It's called quick-quick settings. Below it should say something like show quick settings if there are no notifications.Uncheck that box. If your looking for tabbed quicksettings like in sense 3.0 or 3.6 try out trickdroid. You have to flash the tweaks add on but you have a lot more choices it also comes with leedroid tweaks apk
