3 325i Well-Known Member Mar 26, 2011 #1 I have just installed the Leedroid ROM but the wifi does not work, i get WIFI error. It works fine on other roms. Anyone know how to fix?
3 325i Well-Known Member Mar 26, 2011 #3 I think my problem is kernel related. What is the best kernel to use with this rom and where can i download it from? thanks
G GrenW Android Expert Mar 27, 2011 #5 Never had a problem with the kernel that comes with it. There is a new kernel if you need it which you can find in the Rom thread at xda.
