Legend questions
Knighton
Hi all, just picked up a Legend on Vodafone and after 4 years of a Nokia N95 I'm really hooked.
I have a few questions though, is there a way to separate email/text/warning notifications? I have a customised text alert I like to use but the Legend uses it for email alerts and also if something disconnected or there's a login problem etc.
Also I'm using Chomp SMS but once I've read the text message the alert at the top of the screen keep telling me there's an unread text in the standard text message folder, are there any workarounds for this?
Yes - set the notification via each apps settings rather than the global one you have set.
Turn off notifications in the default messaging app and just setup Chomp the way you want to be notified.
