I am planning on switching to the 4gb tethering plan, which is apparently a very uncommon thing, as the only info on tethering I have found is on how to do it for free. I assume the approved version is a little different, so I have a few questions (I'll be using usb tethering).
Do I need to download anything on my Atrix or computer beforehand? Is there some AT&T or Motorola provided app I need? Are there any settings I need to adjust?
I haven't had access to wifi for months, so I haven't been able to grab the last couple updates. Will that be a problem?
Sorry if these are obvious questions, but I haven't been able to find any kind of guide on this and I just want make sure everything works before I go and give AT&T more of my money.
Thanks.
Thanks.
) anyways. Once the tethering plan is active with AT&T or whoever you go with, go into settings --> wireless --> tethering (or mobile hotspot, can't remember what it is called now that I am in GB) and enable wifi hotspot or usb tethering. It will check with AT&T if you have the plan, and if you do, it will activate and start working. Simple as that. Just make sure you setup a wifi password if you do
I also recommend downloading 3G Watchdog - free app. As it will monitor your data usage so you know if you get near the 4GB limit.
