sfbloodbrother
Extreme Android User
just joined![]()
Awesome thanks for joining the team!!!
just joined![]()
I just checked on the kindle to see how this thing is running and it is giving me an error message? It says I don't have any device detected ? I pressed on the help button and it says I havnt accepted the google play terms....but I HAVE!!!
what do I do now?
Unless you have sideloaded it, the Kindle doesn't come with Play. It is a fork of Android so may not be compatible.![]()
I think it is sideloaded on there...but maybe I can't access all the apps unless its rooted...which it is not...What's weird is that I thought I signed up ...and it was easymaybe I didn't wait to see the error message...or maybe it IS just down....I'll try to figure it out
What if you got BOINC from the Amazon App Store Thing? Amazon.com: BOINC: Appstore for Android
https://play.google.com/store/apps/details?id=edu.berkeley.boincNew to v7.2.39:
* Added support for Ouya and other AC powered devices.
* Added support for x86 and MIPS powered devices.
* Updated translations.
@sfbloodbrother, are you also-known-as Vishera?
You're kicking our butts!
I've just joined the team as well! I've been waiting for the AF team since it was mentioned in the F@H thread, can't wait to rack up those points now
And I'm gonna install it on my PC too, only problem being do I install it n my HDD or the SDD![]()
That's great news!Sweet! The new version of the Android BOINC client supports Ouya - I finally have a use for that turd!
Heck yes!
Nice! Running 4 projects. I forgot. What processor does the console use?
Not bad for under 24 hours of churning.
Can someone provide some more details about what actually we have to do means what does the app do after installing on our phone and what does the term "computing" means??? I dint got any idea about what actually i have to do after installing the app and how does its gonna help so can someone elaborate it in detail please.
I think a fair question is whether this puts folks on limited data plans at risk of burning that allotment or can communication with the mothership be set to use WiFi only?
In a nutshell, BOINC will use your device's idle processing power (when you're not using it, of course) to perform analysis and computation on tiny chunks of data related to medical or technological research. Once the processing is complete, BOINC will return the results to The Mothership, where they'll be combined with results from all of the other devices participating in the program. The tiny chunks will add up over time, and perform research on a much larger scale than would be possible with just a single computer or even cluster. You'll receive credit/points for each chunk of data that you successfully process and return. By joining the AF team, those points will be combined so we can see how much good we're doing together.
Does that help any?
I could Not have Said it better myself!BOINC has an option to restrict data transfers to wifi-only, and also a configurable daily transfer limit to keep it from burning through data if that option isn't selected. :thumbup:
