lets see those speed test scores!!!
jree
EDIT: 3G Numbers only, No WIFI connection speeds.
I just rooted my phone two days ago and I don't know if it had any effect on my speed test numbers. I know rooting it almost trippled my old quadrant scores after the lag fix. I wanna see if it has any effect on my download and upload numbers. Before I was getting no better than 4.8 mbps download and now today I'm getting 5.8 to 6.0 mbps. My upload stayed virtually the same.
I'd like to see whether your stock, rooted, overclocked, or what. Main reason I ask cause sometimes when Im browsing the we it seems like the lag fix was the best thing since sliced bread and other times it feels like I didn't even do anything.
Also, the Dev of the root lag fix bundle app updated today so...
Rooted, stock ROM, lag fix applied. San Diego, CA, testing to Los Angeles, CA servers:
This is what I get on the regular. I applied the lag fix and two days later are started getting these numbers. Thats why I wanted to see what the average Vibrant owners were getting. I've had mine jump up above 6 mbps today
You can get very different speed results depending on the test server you select.
I just got a 5200 using the closest server to my location, but then got a 8648 when I selected a server in a larger city that I know from past experience gives very good results. I'm using wifi with a G connection. If I had N it would likely be much better.
My upload speed is throttled by my ISP, but I'm getting the same speed, or even a little higher, on my phone than I do from my desktop PC.
(I'm not rooted, so no lag fix or custom ROM)
I was under the impression you wanted 3g results. People are posting wifi scores.
I do want 3g scores. Sorry if I wasn't clear on that. These are the scores that I was getting over 3g, not wifi
My 3G results are pretty bad. This is at my house.
First try
0.27 Mbps down and .077 mbps up
2nd try i got 0.61 mbps down and 0.93 mbps up
sep 7, 8:17am
Tampa FL server: Ping 72ms, Download 5317Kbps, Upload 603Kbps.
Not bad...from Orlando
3G, NOT using WIFI.
WITH WIFI= 12,432 Down and 1,898 Up
Rooted with Stock ROM and Lag Fix...
3G Standing in my front yard midway between Tampa and Orlando...
Wi-Fi standing in my house...
Hey new to the community and also to the android family, i ran speedtest .net on my vibrant its a stock 2.1 no mods what so ever and i took ten tests in each place, @ home my download avrg speed is 5.98 mbps and upload is 1.6 mbps @ work [i work in a hospital where i have normally 2 to 3 bars, my dwl avrg speed is 788 kbps and upload is 128 kbps, at the beach where supposably the H+ is available is an avr of 3.11 mbps for down and up is 1.62, needless to say the H+ symbol never showed up it was on 3g when i ran the test still waiting for the H+.
btw my location is jacksonville fl, and i noticed my up speed is virtually the same all the time. I'd show you pictures but like i said im a noob to the android world that just came from the iphone band wagon.... and I LOVE the vibrant with the android os, I would recommend to anyone who is in the market of buying,
Wow, how do you guys score so high on 3G? When I'm in my house I usually only get 1-2 MB per second. I'll test this later.
How did you get the compact version of the speedtest app? I like!
@Android Amature
After you run the speed test, hit the results tab, then press menu, then email the result. Choose whatever method you want and the result will generate the rectangular version of the test, probably in png format. There may be another way, but that's how I do it.
A
