Lg 1700mah battery. Test
Battery just came in the mail time to test :)
Sent from my LG-MS840 using Tapatalk 2
The real way to accurately report battery performance is to document your activities and how long you do them.
Saying something like "I used it a lot today" isn't gonna tell us much as different functions will have different effects on battery life.
never ever said anything like i use a lot today plus i did the accurate battery report performance and such
Do you have a link to where you purchased this battery from Verizon? I cant seem to find it.
Can you take some screen shots on the performance?
Battery Monitor Widget works great!
I too have battery monitor widget pro but that app only measures battery capacity and not performance.
It does give you some estimates for various functions but they're not necessarily accurate.
For example:
I just got the 1700 battery and it fits the phone perfect. It feels slightly heavier than the stock battery but not much difference. I will see how long it lasts. How many charge cycles should I do. Do I wait until it depletes completely or charge at 10%?
You should let it deplete to zero and then charge to 100 once.
Any updates? I too was considering this battery, found them on verizon site for around 20. Would love to know if it's a good solution.
