CBLJazz
Member
Since i have had the droid for 3 or 4 months i thought i understood the
sd memory car setup structure-
DROID SD SETUP
1. Programs often create their own folders on your card
2. if you want access to files like photos, videos, alarm sounds, notification sounds, music files and ringtones
you create a folder on the card called media and place several folders inside it.
MEDIA
>alarms
>notifications
>music
>camera
>ringtones
>videos
If you correctly place files where they belong, access to them is available. For example. All of the sound files in ALARMS would be available as alarm sounds.
The LG ALLY sd structure appears different because the files i placed in alarms where NOT available!
What is the correct sd structure for the ALLY?
DROID SD SETUP
MEDIA
>alarms
>notifications
>music
>camera
>ringtones
>videos
